![]() | Home > Maintenance & Mods (L322) > Handbrake adjustment wheel seized |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Brake caliper hasn't seized has it? |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
No brakes Are fine. It is also only registering 13% on the handbrake test. Can the cold weather have had an effect? It has been sitting unused for the last 4 days |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
can you not disconnect the handbrake cable to free up the shoes.. ... - .- -.
They want to take the hub off and look at the shoes! They think that the adjuster may have seized hence the poor jandbrake perfromance
| Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011
When I fitted my new brake shoes I split the adjuster and lubed it, worth doing if they eventually get hub off. |
there's a hole in the hub where you can put a screwdriver in and adjust the shoes, i gather they have tried this without success...its best to get it sorted James tbh.. ... - .- -.
If you had the pads replaced a year ago I would have thought everything should still be free.
replacing pads doesn't affect the brake shoes .. ... - .- -.
Meant shoes. |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
They have the car in neutral? It's not the gearbox holding it? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
No all the other wheels turned fine - just the rear left was stiff. THink the new Shoes put on for the last MOT have seized somehow, probably due to it not being used very much (have been away for a while).
| ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276
I'd say yea, seems a bit draconian to fail the car on something so trivial |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Possible the cog on the adjuster is catching on the spring. A bit of poor design in the drum I feel.... .
| All times are GMT |
