![]() | Home > Technical (L322) > 2010 Problems.... |
OK 753 - TV/DVD in motion, step by step (2010 - but 2006 etc similar)
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 ![]() ![]() |
I tried, but can't seem to get to work - no hidden menu. Or am I just being a bit thick?!? |
Make sure you are on the "home" screen, i.e. the one with the options for NAV, PHONE, AUDIO etc, very top middle press finger to screen, hold for 5-10 secs, then push the HARD NAV key - not the touchscreen one, until the DIAG PIN screen pops up |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3813 ![]() ![]() |
dantheman think this might only work on 2010's |
It worked 100% in my 2006 FFRR 4.2SC - that's how I knew how to do it |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 412 ![]() ![]() ![]() |
It works on MY2007+ at least.
I can get the Same as what Thrasher has described, just dont think i tried it with the TV on |
I have the first of the 06MY facelift: tried as described Thrasher - still no joy. |
Got it working while driving but i take it you have to go thru the procedure all the time when you switch the ignition off as it don't seem to store the settings ........ ====================================
Just like all the codes, none stay after ignition off.
Yes please. You could even make a list of the ones you know and what they do. |
I will assume most people know the 1791 hack? Anyway, if not, hit the "home" button for the nav screen (2006-NOT 2010) so you get the menu with dest entry etc, press top middle of screen until Pin pad appears - enter 753 here and you get all the sat nav diags.
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2074 ![]() ![]() ![]() |
Thrasher
