Home > Technical (L322) > Niggly sound problem since fitting MK4 dvd Nav
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Ever since fitting my MK4 dvd sat nav in my 2003 RR i get some pauses in the volume, almost like a traffic anouncement is coming but its just a slight pause then back to the music, happens with radio, cd or Ipod. Anyone else get this? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #166092 20th Jan 2013 3:44pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Dude I'm wondering if u have a iffy nav, mine is fine and I have tmc active also urs wouldn't let us select camera alert and mine does
I wonder if urs is programmed right
Post #166097 20th Jan 2013 4:09pm
JohnnyDangerous
Who could check that dude, in all other aspects it works fine, of course it could be really strange if it does it where there are cameras !!! One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #166099 20th Jan 2013 4:11pm
switch of all traffiv alerts on the nav, might help to narrow the fault down.. ... - .- -.
Post #166141 20th Jan 2013 5:50pm
Baris
I thought I would also reply here, so people know the reason for why this happens. We get this problem, all the time over on the BMW forums.
The modified firmware with the speed camera alerts, will dim the music, regardless of if you have it on Or off.
So you either use the camera alerts, or install the Oem firmware.
Another note on the speed camera firmware, if you live around London, it will keep crashing the system, when you go past a certain spot, every time.
Post #168559 29th Jan 2013 9:25pm
thanks Baris. Thumbs Up ... - .- -.
Post #168567 29th Jan 2013 9:37pm
JohnnyDangerous
But I want the audible camera alerts, will your solution allow these to work? If I could switch them on in the menu they would work but the camera alert section only alters language. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #168743 30th Jan 2013 10:39am
