![]() | Home > Maintenance & Mods (L322) > ZF5HP24 Fluid Drain and Filter Change....by Saint.v8 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
all comments here re Saints.v8 excellent 'how to'...
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
Just to add one thing, once you have drained the sump put the plug back in and run the car for a few seconds, do this a couple of times and you will prob get another litre out of the box, if you have no apparent leaks measure how much came out and this is roughly what needs to go back in. One day your life will flash before your eyes......................................make sure yours is worth watching!
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
That was a truly excellent technical thread! |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
excellent write up sir and great how to for reference,
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 ![]() ![]() ![]() |
nice service, are interesting also any blue you used, where to be found? |
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 ![]() ![]() ![]() |
Many thanks for your kind responses....with the cost of garages nowadays it makes sense to try these things ourselves....and I am glad it helps others to save some cash...!! |
Sorry Madcima, I am not sure I understand your question....maybe you could rephrase it please? ![]() ![]() |
I'm sorry, basically, I want to buy those ramps blue as you used, I wanted to know where I could find it |
The Ramps I got from a company in the UK called Machinemart...
another great write up, you should change your name to ,Haynes |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
I was a bit worried about those ramps, what weight rating do they have? Per axle / per ramp ? .
are crw25 or cr2? |
CRw25 and are rated at 2.5 tonnes a pair (1.25 tonnes each)
