Home > Maintenance & Mods (L322) > 2002-2005 V8 (M62) In Tank Fuel Pump Replacement.by Saint.v8
please post your comments here...
http://www.fullfatrr.com/forum/topic16152.html
in wiki.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #166378 21st Jan 2013 8:06pm
What a fantastic guide... Great work.. Thumbs Up Previously..
Post #166383 21st Jan 2013 8:23pm
Excellent!!! Bow down Si. <This is my name.
Post #166396 21st Jan 2013 8:48pm
rathbranV8
Ireland 2002 Range Rover SE 4.4 V8 Oslo Blue
Did this a few years ago and wish I had this as a reference
Excellent work sir Thumbs Up
Post #166475 22nd Jan 2013 11:12am
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Great right up and luv the use of x5 parts
Post #166478 22nd Jan 2013 11:14am
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Many thanks for your kind words....
I was over the moon it went so well and also the use of an X5 pump saved me a bucket load!!
Post #166592 22nd Jan 2013 6:47pm
klf400
top marks , if only rave was this good Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #166614 22nd Jan 2013 7:45pm
Andy
Is the td6 the same?
Post #167355 24th Jan 2013 11:10pm
Saint.v8
Process is the same, pump in the bottom of the housing is different....
Plus the TD6 has a second pump mounted externally to the tank too....
Another RR owner has just done the in tank pump on the TD6 using this pump....
http://www.ebay.co.uk/itm/271123594905;jse...mp;afsrc=1
Post #167359 24th Jan 2013 11:26pm
Andy
Mine cuts out when the gauge hits 1/4 tank and the range shows around 78 miles. Is that the inner pump or outer?
Post #168676 29th Jan 2013 11:48pm
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
Should I be able to hear the pump?
Great write up thanks Saint.
I think my pump may have packed up, I have checked the relay in the rear fuse box, should I be looking for a separate fuse too?
I have stripped the back out, carpet up and inspection hatch open and cannot hear a thing from the pump when the ignition is turned on. Is silence normal?
Are there any other tests I can do before I attempt replacement.
Any advice appreciated as always.
Daz 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #168854 30th Jan 2013 6:08pm
