Home > Technical (L322) > HELP - Can't Lock my Car !!!
Britishlion
Hi All
So, bizarrely today I used the car all morning everything fine until 1300 today the central locking stops working maybe a flat battery, changed the battery, nothing, tried using the key in door as a manual overide. nothing again ?
So my car is open, as in doors unlocked. I can lock the doors from the inside button, but outside > nothing. cant use key or key fob, I have tried searching the problem but cant spot anyone who has had both remote and manual lock out ?
I can start the car fine and no immobiliser problems
Any ideas to assist me securing the car ?
Thanks
BL Thumbs Up
Post #166401 21st Jan 2013 9:27pm
alan
2002 Range Rover Vogue Td6 Alveston Red
Hi can you leave the window open then lock it using the inside button then press the button on your remote to close the windows.
Post #166412 21st Jan 2013 10:37pm
One word,
Fuses!! Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #166418 21st Jan 2013 11:04pm
Try Fuse 11 30A in the front fuse box.
I'm guessing the manual locking of the drivers door may not have worked for a while and you've never noticed it ?
Post #166420 21st Jan 2013 11:24pm
Britishlion
Thanks for all your help everyone i will try in the morning
Post #166424 21st Jan 2013 11:44pm
ebajema
I had a similar issue when I just got the car. It wouldn't lock due to one of the door switches not working well, thinking the door was not closed. It would also keep the interior lights on. It went away by itself (it only occurred 3 or 4 times anyway) as I used the car every day (it had not moved for 2 years). MY 2010 5.0 SC Galway green and sand interior!!
Post #166445 22nd Jan 2013 9:08am
