![]() | Home > Maintenance & Mods (L322) > 2010 conversion, air filter OEM look |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
a 'how to' will be great, thanks.. |
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
| klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210
i also have been doing my conversion over the past weeks when i have time [ allways seems to be something else to do ] and i have been able to fit the 2010 front end and keep my oem air filter housing and intake pipe from the inner wing , its not easy and is a very tight fit
| glennhoward Member Since: 26 Nov 2012 Location: kent Posts: 58
That sounds like a good fix, when the weather changes I may also look into trying to fit the lower housing. It was only when we couldn't use the FF that we came up with the solution to re use the oem part. I will try to put a how to guide up at the weekend with photos if you have any pictures of how you fitted the parts they would be good to see. |
| JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833
The moulding was my plan. One day your life will flash before your eyes......................................make sure yours is worth watching!
