Home > Maintenance & Mods (L322) > fitment check 20" sport wheels
daz
United Kingdom 2004 Range Rover HSE 4.4 V8 Tonga Green
hi any one know if 20" rrs supercharged wheels will fit on a ffrr 04
cheers
Post #16558 14th Apr 2010 9:32am
Vogue
yes, you may need to change the wheel nuts though - the off set is more with Sport wheels, i.e. they stick out further. LR even fitted the same 18" wheels to both Sporty SE versions and FFRR 2006 MY vehicles with 18" wheels.
Post #16567 14th Apr 2010 10:42am
daz
thanks vogue chasing a set on ebay at moment fingers crossed
Post #16644 14th Apr 2010 9:32pm
StevieH
Daz
They will come with the wrong size tyres, probably 275/40/20...you will need to change them to 255/50/20 to keep rolling radius correct
Post #16656 14th Apr 2010 10:44pm
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
Check the trye wear on the 275 40 20s as most wear Contis and outside edgewear is a problem although may not worry you as you will have to change the tyres for a Full Fat - strictly speaking 255 50 20s will be a bit skinny for the RRS wheels
Post #16671 15th Apr 2010 10:02am
If you must fit RRS wheels to a FFRR Rolling Eyes , make sure they are genuine ones and not fakes which are not built strong enough and prone to cracking. Discovery 4 HSE
Post #16695 15th Apr 2010 6:33pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
I found this thread as im looking to put some sport wheels on my 04 Vogue
Will the tyres that come the wheel be ok for the time being? as im now worried about the rolling radius
thanks
Neil
Post #92614 16th Nov 2011 11:32am
RRS wheels with 275/40/20 will fit and be ok..
your speedo will be out by reading 67mph at 70mph, the diameter will be 35mm less than the standard 255/50/20 size..
the 275/40/20 do look a little small in regards to the size of the fullfat.. ... - .- -.
Post #92616 16th Nov 2011 11:37am
