![]() | Home > Technical (L322) > HDC INACTIV, Very strange |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
I had this problem for a while. Even changed a couple of ABS sensors to no avail.
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 ![]() ![]() |
I too have the same problem, normally the HDC inactive welcomes me each morning with a bong. Yet since its dropped cold and im welcomed with the outside temp warning, the HDC inactive has gone.
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
Same here! gone fishin' |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
Hi from Düsseldorf to Düsseldorf, it is the battery!!!! Even if new! Have some clients with same problem, when you take the car over night to a charger, in the morning NO "HDC inactiv...."
L322RR Member Since: 06 Oct 2011 Location: Düsseldorf Posts: 51 ![]() ![]() ![]() |
Hi from Dusseldorf.
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
Listen to Ulli he is a LR crack |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 ![]() ![]() ![]() |
I used to get this all the time - even with a new battery, until I installed a second battery in the back. This runs through an isolator that only cuts the main battery once the volts drop down a fair bit, so day to day, when I'm not camping and running a fridge off the system, the whole show stays at a slightly higher level of charge now than it did before, and after a few days of running this system, this fault has not been seen since. My guess was that it was VERY voltage sensitive, but with you guys saying it's sorted now it is colder, sort of seems to counter this, as the battery would be under a lot more stress at this time of year for you guys, so now I'm not so sure, but mine is fixed, and a few of you along with it, so all good I suppose... |
