![]() | Home > LPG > Amazing honesty from LPG fitter |
| oliver9627 Member Since: 25 Oct 2012 Location: Chipping Norton Posts: 51
Well fair play to him for being honnest. Not sure about the 2006 onwards bit, but i know you have to use a valve lube on the later engines.
| JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204
Thats a nice fella.
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
Why did you buy a petrol FFRR? Probably with view or idea to get converted. The petrol has a lot of plus sides and some are the performance over diesels, quietness etc. so when your doing your working out as to whether or not its a viable option think about working out costs compared to running a diesel. Obviously 0.71p p/l compared to £1.39 p/l will make things look different. Not sure if that makes sense? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3284
Everything he said is true. however on LPG (currently at 70ppl chez moi) my cost per mile is 25p, same as my TD6. less than 25% less efficient than petrol but nearly half the price. the maths speaks for itself.
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
BLs miles have gone up a bit more than a smidge recently I think due to unforeseen things |
| bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055
He may be well intentioned, but its only his point if view.
| SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457
my SC runs on a Prinz twin injector system with lube
| Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 798
Selective memory? MY23 D350 HSE On my 7th RR plus various other JLR vehicles |
No.
Just doing my duty to keep you factually correct on various forums |
| TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1201
I did some digging on this very subject some time ago relating to LPG conversions on AJV8 (n/a) engines. I spoke with JE Engineering who told me the same regarding the valves.
I'm sure they encountered some issues, but as above, find me an SC with valve problems caused by LPG. And somebody needs to tell all the converted L322s, sports and xjr's which are running without any issues.
Mine did. As per our prior discussion On my 7th RR plus various other JLR vehicles |
| johnbowling Member Since: 31 Jan 2013 Location: manchester Posts: 12
prinz have a great page where they have a calculator showing you how much you save on gas per year based on your mileage your mpg and current fuel costs
