Home > Technical (L322) > Bluetooth always on?
supershuttle
I have a problem with my battery going flat from time to time - regularly in fact. One thing I have noticed which may or may not be relevant is that if I take a call on my mobile in the house the BT in the car takes over, which means its on even though the car is locked up and "asleep". My previous cars have not done this - so my question is simple is this normal behaviour or should I be taking a closer look.
I have a Wiggs module if that's in any way relevant.
Any experience shared would be gratefully received Thumbs Up Geoff
Post #167578 25th Jan 2013 8:26pm
Switch your bluetooth off on your phone either that or park your car at the end of the street Wink you must be quite near the car when you take a call Shocked ====================================
Post #167581 25th Jan 2013 8:35pm
supershuttle
It's the downside of not having a country estate, if there were no glass I could touch my car though the window from where I'm sitting Very Happy Geoff
Post #167585 25th Jan 2013 8:41pm
supershuttle
BUT is the car still looking for a BT connection all the time Geoff
Post #167586 25th Jan 2013 8:42pm
My guess is when you are phoning the car might still be picking up the signal and booting up if it is not properly going to sleep …
No doubt someone qualified on this matter will be along Geoff ====================================
Post #167593 25th Jan 2013 8:56pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
I always find it irritating that when the phone rings in my pocket when on a visit somewhere I cant answer as the call is going through the car even when car locked up and 30 yards away. Probably a way of answering the phone in a specific way but if you just hit the green answer thing on the screen it never works. Ho hum.
Post #167599 25th Jan 2013 9:03pm
simon1233
Hi Geoff
My BT module stops hijacking my calls almost immediately after I have turned the car off, longest that it has affected the phone is maybe 5 minutes after locking the car, but normally it is pretty instant. If your BT module is staying on that could explain your electricity issues?
Post #167602 25th Jan 2013 9:06pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
If I get a call immediately after getting out of the car and prior to the car 'going to sleep', it automatically transfers to car.
After the car has gone to sleep, it's not an issue, the phone operates as intended. Similarly if I unlock the car to get something out, then re-lock it, the car maintains the connection for a short time, until it goes back to sleep.
I too don't have a 'West wing' and my phone is almost always within range of the car.
Not sure what phone you have but a good test would be to park up car, lock it then watch for the Bluetooth symbol on your phone to go off. If it doesn't you have a fault. A battery disconnect with the reset process (touching the pos and neg leads together once disconnected, sorted out a Bluetooth gremlin I had. Maybe give that a try.
Make sure to let the car power down fully prior to dis-connecting battery, think the hand book advises 10min wait. Hopefully someone else may be able to confirm this? If not check out the WIKI section, sure there is a battery disconnect procedure in there. Hope this helps.
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #167610 25th Jan 2013 9:13pm
supershuttle
I'll just pull the BT module and see if it makes any difference or can I switch it off? Micks right I need someone who knows stuff to advise Geoff
Post #167612 25th Jan 2013 9:14pm
wiggs
If some thing is stopping your car going to sleep the Bluetooth will always be on .
If you want to bring it here I can do some tests for you .. Check the Bluetooth on my test rig / disable it in the car / check car voltage draw when it's asleep Bluetooth Exchange www.bluetoothexchange.co.uk
Post #167615 25th Jan 2013 9:24pm
supershuttle
That's what I call good service Thumbs Up Geoff
Post #167628 25th Jan 2013 10:00pm
My newer module stopped almost as soon as the key was removed from the lock. My older upgraded one seems to take a few minutes for the car to go to sleep to fully close down but on an iPhone you can change tte audio source once you answer the phone Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #167632 25th Jan 2013 10:25pm
Sorry to interupt your thread but did you get my PM about DVD Changers Adrian?
Post #167680 26th Jan 2013 3:10am
wiggs
I did thanks Thumbs Up
I thought I'd replied Embarassed Bluetooth Exchange www.bluetoothexchange.co.uk
Post #167687 26th Jan 2013 8:32am
