Home > Maintenance & Mods (L322) > headlight washers on a 2002 td6 hse
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
how do they work no sign of any nossels ect on bumper ,belive they need to be working for mot (not due till late june) but want every thing to be working have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #167378 25th Jan 2013 8:22am
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
They only work with lights on, and every first and sixth wash of your window
Nozzles are located in the pivot point of the arm,
Not sure it's an mot fail tho RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #167381 25th Jan 2013 9:15am
For MOT, if the car has HID headlights, the headlight washers and wipers have to work otherwise its a fail.
If the car has halogen headlights, no washers or wipers needed.
Post #167397 25th Jan 2013 10:06am
If you look at the headlamp wipers, the cap you lift to remove the 10mm nut which in turn removes the wiper arm of off the spindle from the motor, is where the washer jets are situated...
If you flip up the cover cap, then wash your windscreen a hole bunch of times (i think its every 5 or 6 washes the headlights get washed) don't forget to turn your headlights on... If they are working but the jets are blocked you should get a jet of water out of the center of the 10mm nut securing the wiper arm on...
Then you have blocked washer jets...
If that doesn't work its fuse checking time... Thumbs Up
Craig Bow down
Post #167398 25th Jan 2013 10:06am
trainmanone
ok thanks for that info guys just checked the wiper arms drivers side has a Nozzle on it but no water lift it up no water,pass side has a drivers side cap so need a pass side cap then see what happens ,dont suppose any one got one they dont need
pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #167427 25th Jan 2013 11:11am
daveturbo
washers
i need both so would buy a pair if any for sale.
Post #167985 27th Jan 2013 10:57pm
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
I need one for the drivers side Wink gone fishin'
Post #168164 28th Jan 2013 5:47pm
