![]() | Home > Technical (L322) > anyone familiar with the front hubs? |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
Hi all.
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
An engineering shop may be able to help you if you get the hub off. One day your life will flash before your eyes......................................make sure yours is worth watching!
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
Why not grind the disc around the bolt until you can remove the disc and then remove the remains of the bolt with Molegrips or similar.
Do you mean the grub screw that holds the disc onto the hub?
^^^ That will be number 9 then....no not that number nine |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
A good engineering shop with a spark eroder will get it out without damaging the threads |
Hi gents,
Hi Woodie, if you grind the 9 bolt flush with the hub, you should be fine as I agree with the above, you don't need it. It only helps keeping the disc in place while you mount the wheel.
Workshop Manual , with pictures |
If the disc is solid enough, then as long as its not my dust shield, which it shouldn't be as I just fixed it with penny washers, it must me Tue long bolt I've broken off catching inside of the hub somewhere. What is really like to know is if I can access the back of bolt 9 when the hub is removed, other wise its going to be a new hub. MY2010 TDV8 Vogue Ipanema Sand
