Home > General (L405) > Clarkson's abrupt change of tune...
Page 2 of 3 <123>
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
If they were vents then there would be ducting to them from inside the engine bay, there isn't. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #168651 29th Jan 2013 11:05pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Agreed that there is no ducting, but hot air most certainly comes out of them - again, why go to all the effort of making actual vents when you can just stick a bit of plastic on?
Post #168654 29th Jan 2013 11:08pm
DMRR
'Design' - there's no appreciable heat from them - I've owned a 4.4, 4.2, 5.0 and now a 3.6 ... none have 'pumped out heat' from those plastic decorations. I'd say they are as warm as the wings..... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #168658 29th Jan 2013 11:10pm
Philip
Heat most certainly does come out of them - how could it not, given that they are where they are? You don't need a direct line of sight for heat to find a way out.
Post #168661 29th Jan 2013 11:16pm
DMRR
At even 5mph they would cease to function as vents *if* they were vents, which they are not. Take off the 'vent' and see what's behind it - it's not a gaping hole into the engine bay! Just remember the wings are double skinned. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #168662 29th Jan 2013 11:17pm
Philip
How on earth could they not function as vents with air moving across them when the car is moving? It's a low pressure area, a vent there will extract air (and heat) from wherever is behind it. Open your windows on a cold day and let me know if it gets cold inside ...
(I have removed the vents and looked by the way).
Post #168665 29th Jan 2013 11:29pm
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
I shouldn't worry, the panel gaps between the bonnet & front wings on the L322 always ensures perfect cooling Laughing
Post #168667 29th Jan 2013 11:34pm
DMRR
So...let me get this straight, you think they vent the engine bay - I can't find the astounded emoticon Rolling with laughter
Er unless you hadn't noticed the engine sits in a BAY which is funnily enough not enclosed ..... so your 'windows down' analogy does not and cannot be compared - unless you've removed your floor. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #168673 29th Jan 2013 11:44pm
Rolo
Laughing Laughing
Post #168675 29th Jan 2013 11:46pm
Philip
This is like pulling teeth. There is heat from the running gear behind the wing panel, be it via conduction, convection, radiation or whatever. The vent in the wing can do nothing but extract that heat via the air flowing across it when the car is moving - whether it is the most effective and efficient way of doing that is irrelevant - that is what it does.
Post #168686 30th Jan 2013 12:15am
DMRR
So your 'vents' are hotter than your wing panels after a run? Mine aren't ... the double skinned wings stop anything getting out through the 'holes' in the outer skin. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #168696 30th Jan 2013 12:40am
Philip
Read the Clarkson column - the targets of his criticisms are the interior disco lights, the projected "Range Rover" from the puddle lamps and the silly door vents (and Gerry McGovern). The theme of it is nothing that hasn't been discussed at great length on various internet forums - the new car is too glitzy to be true to its roots and, by changing to suit the desires of tasteless people, it stops being what they wanted to buy into in the first place.
As for the vents - they're plastic so they don't get appreciably hot. You can feel heat coming out of them though.
Post #172088 13th Feb 2013 8:53pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Next time I'm working a weekend I'll get the works thermal imaging camera out and take a look at the vents, will try and take a pic with it and post my findings here.
Post #172092 13th Feb 2013 9:12pm
On my TD6 the air inlet tract sucks from the inner wing to the void between it and the outer wing and draws air from this area and can be felt when the pipe work is all attached properly. on the drivers side even though the vent is right behind the drivers side headlight. its not a massive amount but enough to feel.
heat rising is just physics law 101, BUT in motion other factors are taken into account and a lot of the engine bay heat gets pushed UNDER the car as its designed to. Ever wondered why the back of the cars seem drier than the sides and so forth? The exhaust and cats add to this admittedly but the heat goes thru the ac rad/intercooler, the normal rad, then over the engine, hits the firewall and flows down the slanted firewall out the bottom of the rear engine bay Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #172093 13th Feb 2013 9:12pm
Philip
That's convection. Don't forget radiation and conduction.
They might not be an effective method of removing heat, but if there is a heat source behind there (and there is), some of it will be extracted via those vents.
Post #172102 13th Feb 2013 9:20pm
Page 2 of 3 <123>
