![]() | Home > Maintenance & Mods (L322) > HDC / Air Suspension / PAS / Speedo Inactive |
| Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94
According to RAVE, the Speedo gets it speed signal from the Rear Left ABS sensor via the ABS ECU...if yours has failed, the ABS system has no information to pass on to the Instrument Pack....
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Same happened to me when the front wheel bearings, arm rubbers and airbags were replaced. One sensor died and all the faults (apart from the speedo) came up. Replaced both sensors and all problems gone. MY 2010 5.0 SC Galway green and sand interior!!
| T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187
All sorted - the wiring in the loom upstream of the sensor, and sensor plug had been damaged - joined it back up, and all was good again! l:OolΞΞΞΞΞΞloO:l
| Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964
Just as well having replaced both front struts the day before! l:OolΞΞΞΞΞΞloO:l
| All times are GMT |
