![]() | Home > Maintenance & Mods (L322) > Water / Condensation in rear lights |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35852 ![]() ![]() |
how did you get your range into your frontroom then... |
good point...i've reversed the car a bit.. |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
The problem is it will come back again |
Happens on my led lights too unfortunately with the leds the light unit does not generate any heat so takes ages to evaporate |
Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143 ![]() ![]() ![]() |
Was there ever a recall on the lights because of the water ingress? 2002 Vogue Epsom Green with Ivory Leather.
Nice way to blister the paintwork |
Have you taken the bulb holders out? The air needs to circulate to get out... Or you will be left with a puddle in the bottom and when it gets cold again the puddle will go all over the inside of your lens again...
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3985 ![]() ![]() ![]() |
I think the only way to cure the problem is to drill a discrete hole in the bottom of each lens to allow any water that leaks in to drain. |
So took near side rear light off. Took bulb holder off. Was a fair amount of water in there which surprised me as hadn't seen any when on the car, just fog.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
You should have let it acclimatise before fitting. If it was even at room temperature when you fitted on a cold day, yes, it would probably have condensation. Previously..
Fame Member Since: 01 Dec 2012 Location: Oliveira do Hospital Posts: 42 ![]() ![]() ![]() |
nicedayforit's solution works well on my Defender, not one, but two very small holes at base of lenses, allows air in, and fog out. Range Rover Vogue TD6 2002
Only works on non led lights though |
