![]() | Home > Maintenance & Mods (L322) > Water / Condensation in rear lights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35852 ![]() ![]() |
i thought all rear brake lights were led.... i drilled holes as well and it helped muchly but sometimes i still got condensation... ... - .- -. Y. O. L. O. . |
Oh Stan..... |
so up till then its brake led and side/fog is a bulb....didnt know that... |
Ahh, then i see the sarcasm was inappropriate sir |
didnt take any notice Craig, i'm used to it... |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
i removed and warmed them in a cooling oven . within a week same issue..
as far as i can see there 3 options to get rid of condensation,
Try touching an LED after it's been on - I think you'll find you'll go OUCH! Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
Yes but doesnt radiate the heat enough so that it demists the lens unlike normal non led units were more heat is radiated. Present :2008 TDV8 HSE
Pretty much impossible task unless you drill.... |
I have drilled and it doesnt work on the led lights. I have used a vacum cleaner worked for a bit / I have removed and sealed around the gasket with vaseline ( old remedy apparently) and it doesnt work. It clears for a while but when damp it returns. Im sorry I changed mine now to leds . It looks bad on normal lights but on leds it looks nasty. |
drill a larger hole in the back where the hole cant be seen....you need a better air flow... ... - .- -.
was thinking i could maybe fit a small solar powered fan in there ! Present :2008 TDV8 HSE
