Home > Maintenance & Mods (L322) > Potential new battery type
mzplcg
So, having come up against the dire lack of capacity in the standard LR battery I looked at the Bosch/Varta 020 which seems to be the de-facto standard upgrade.
Anyway, same physical size, same cold cranking amps, 5ah LESS overall capacity (105ah) BUT is made of AGM technology like proper leisure batteries so they give vastly superior deep cycling abilities, and also (allegedly) are better at starting when down as low as 30% capacity. These babies can apparently still deliver the full CCA value when 2/3rds discharged.
Incidentally this is the same technology that LR are charging a King's Ransom for on the 2010 upgrade programme.
Anyway, being an avid lover of the FBH I have taken the plunge and fitted one of these. After about 10 days of short runs and used the FBH every morning I can report a distinct lack of drama. Smile
Worth considering for some. Here's the link. I paid £170 delivered.
http://www.justcarbatteries.co.uk/index.ph...ttery.html
Post #169999 4th Feb 2013 3:42pm
You could have started something with that. Thumbs Up
Post #170002 4th Feb 2013 3:52pm
mzplcg
Rolling with laughter Rolling with laughter Rolling with laughter
No pun intended right ???
Bow down Bow down Bow down
Post #170003 4th Feb 2013 3:54pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
I think the LR supplied AGM is 95 ah so while that's less than your old battery it's more than the current LR unit so should be great Thumbs Up did it fit in ok ? 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #170011 4th Feb 2013 4:20pm
mzplcg
Yep, same dimensions as the 020 Bosch unit (393mm long) so was a bit of a squeeze. I do have the pyro unit on the +ve terminal as well - 07 TDV8.
Post #170014 4th Feb 2013 4:30pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
I have Banner - Running bull (with AGM), 92ah and 850. Parked in Italy 2 weeks ago for the week, -21 and it started, no issues with the battery at all.
Post #170020 4th Feb 2013 5:12pm
nice find Dom...let us know how it stands up to the fullfat's quirky power consumption.... Thumbs Up ... - .- -.
Post #170025 4th Feb 2013 5:35pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
AGM batteries require a slightly higher charge rate. I've been reading about the 2007 alternators having a limited life. Is this a concern? i.e. is the 2007 alternator up to it? The CTEK battery charger rate for AGM batteries is 14.7v. Normal is 14.4v 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #170029 4th Feb 2013 5:47pm
mzplcg
The Denso alternator is well known for high charge voltages. It is also infinitely re-buildable as I have personally found out. Biggest issue with TDV8 alternators is getting them off the car. That's what is commonly known as a Pig of a job.
However, if the rectifier has gone pop you can get a replacement for about 40 quid. A set of brushes whilst you're there for another 7 quid. Needs a powerful soldering iron and a bit of dexterity. Not rocket science.
FWIW I am seeing 14.8 volts at idle on a Fluke meter. Not calibrated to military spec but no reason to believe it's not accurate.
Post #170035 4th Feb 2013 5:59pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
I don't mean to put the cat among the pigeons, but why not get;
bosch s5 £110 Delivered
Varta 60ah leisure batt £62 Delivered
80 amp fuse £4 Delivered
battery clamps £5 delivered.
Total = 181
a little bit of 8awg wiring and some cable ties and you have 170ah a 5 year warranty on the bosch and im unsure about the warranty on the varta.
Then for a further £35 for a VSR and £10 for a bypass switch and a little more effort and wiring and you have a fool proof, separated twin battery system.
But even if you left it at the first stage you have a much better solution to the single agm varta battery for £11 more!
Post #170060 4th Feb 2013 7:45pm
mzplcg
'Cos some of us store the removeable towbar in the cubby where the 2nd battery would be. Thumbs Up
Post #170105 4th Feb 2013 9:34pm
barracuda816
Will the tow bar not fit in with the spare wheel?
Post #170322 5th Feb 2013 9:26pm
mzplcg
Might do, but not in the official storage thingy. Would need to be wrapped in an old towel or something but there's not a lot of room in mine there either. I already keep a set of jump leads, a properly heavy duty towrope, a 2 foot breaker bar with 22mm socket (wheel nuts), a discovery-3 bottle jack and handle, and a 12v tyre compressor Laughing
I even have a spare wheel in there as well Laughing
Post #170439 6th Feb 2013 10:07am
Thats what the space behind the back seats is for Smile Stops it rattling around and is much easier to get to Smile
I have all my recovery and repair bits in there ontop of the rubber matt's and means if i have any shopping of clobber in the boot i can get to it dead easy Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170442 6th Feb 2013 10:12am
