Home > In Car Electronics (L322) > Aftermarket?
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Aftermarket?
After having problems with my audio system I'm tempted to remove the non touch screen unit,amp,sat nav,dsp,cd changer and tuner and replace the whole system with after market double din ,iPod,sat nav,amps,speakers,subs and new wiring etc
Would removing these stock items cause many problems? I know I wouldnt be able to change the clock time or reset the mpg etc but that I can live without them for exchange of great working audio?
Is anything else connected to this system ie: parking sensors etc?
Post #170097 4th Feb 2013 9:27pm
djharm
Netherlands 2002 Range Rover Vogue SE Td6 Java Black
What are the problems?
Post #170610 6th Feb 2013 11:21pm
SATVC
Only issues with fitting after market units I can see are adjusting the clock and resetting mpg etc??
The probs I've had are amp failing door speaker by door speaker!
Blank screen, sat nav unit failing, subs blown???? The list seems to go on!
Post #170612 6th Feb 2013 11:25pm
djharm
What are your problems with the OEM system I meant....
Post #170615 6th Feb 2013 11:37pm
SATVC
Sorry
First of all the sat nav died so I replaced with a mk4 which I think now is failing? then the door speakers died one by one, so presume the amp is dieing? The screen is permanently blank now? The subwoofers sound blown? I don't think the system was actually that great to start off with so really don't fancy spending the money on it when I could get a million time better system for the same money??
Just really want to know what will happen if I remove all the existing units?
Post #170616 6th Feb 2013 11:42pm
djharm
I have had similar problems, I took all units out to find out what the problem was. Obviously water damage, pins of the TV-unit where rusty, so I cleaned them out and had to solder the positive + straight from the print to the cable cause the pin broke while cleaning, and wanted to try to get it to work before spending money. After that everything worked well except for my NAV witch I had to replace for the 2nd time . Since then I kept my AC on all the time and haven't seen any water since. But I did cover everything with some plastic's.... just in case..
Post #170619 6th Feb 2013 11:56pm
SATVC
I've had a look at most of the plugs and all seams ok? When I get some time I'll go through everything with a fine tooth comb!
If it was that simple I'd life with it, but the blank screen is useless as it is??
Post #170620 6th Feb 2013 11:59pm
djharm
Do you have a blue screen? or nothing at all?
Post #170624 7th Feb 2013 12:08am
SATVC
Nothing, just a back light!
Post #170646 7th Feb 2013 9:25am
djharm
And if you take out the MK4 unit?
Post #170677 7th Feb 2013 12:28pm
SATVC
Nothing, just the back light? I plugged it into the tuner plug aswell with no joy,
Today as I've been driving with no music, the sat unit is making a mad spinning noise?
Post #170793 7th Feb 2013 7:38pm
djharm
Take out the MK4 anyway, and try to find a TV tuner, the are not so expensive. I've seen them go for 60 to 100 pounds. try to go from there, you might end up cheaper than replacing for aftermarket.
Post #170818 7th Feb 2013 8:39pm
SATVC
I've finally decided a new double din aftermarket system is the way forward.
Does anyone have a wiring diagram for the speaker connections at the amp, this should save me re wiring the door speakers from scratch!
Thanks for you help Thumbs Up
Post #172045 13th Feb 2013 5:55pm
the new head unit will probably have all the connections you need if its for the fullfat , mine did for my smax.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #172049 13th Feb 2013 5:58pm
SATVC
It's not the range rover screen going in it'll be a pioneer double din, I'll be losing all the standard screen,amp, dsp, tuner, sat etc
Post #172055 13th Feb 2013 6:25pm
