![]() | Home > Technical (L322) > Possible Injector Failure |
Well for some reason my FF has decided its not getting enough mechanical attention.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35814 ![]() ![]() |
i'm guessing an injector failure would result in a lumpy engine which i dont think you're getting, i would go with the your fuel starvation or air in system theory... ... - .- -.
A lovely way to spend a saturday |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Remember - common rail - check that the electrical connectors to the injectors are all good, before condemning one.
Haven't got a fault code reader. Its really bad once the engine is warm and low and behold I had to stop the engine a few minutes ago when warm and now it won't catch when cranking. It was idling rough just as I pulled in and down on power for the last few miles so its gotta be air in the system as even if two injectors were dead it would still run but like a dog |
good luck on the journey Will.. |
Always happens when you're on a promise! |
Think ill need it. Have a nice sucking sound coming from the engine bay so just trying some priming runs now |
Well i gave up in the end and left it a few hours.
Well it was fine this morning for about 20mins then started again. it held speed fine at 60 for a good 30mins later and some light driving at about 30 and then just died |
Your wasting your efforts. Get to an Indy/Stealer and get the codes read these cars are very clever IT WILL tell you what the problem is.
Problem is gaz i get no warning lights whatsoever so not sure anything will show up on a FC reader unless its a good one like autologic/sdd/FSC-MSV as to see what pressures are being seen by the sensors |
Only OBD-2 Codes will throw the MIL on all the other "Many" codes are stored without a light. Thats why I suggest a trip to a Land Rover Equipped Indy or a Stealer. Testbook can even tell you which parking sensor is faulty let alone diagnose a fault that's stopped the engine working properly. I really think its the way forward to get a quick & safe solution... |
Wish i had bought that £300 msv when i had the chance now |
Also less than perfect BIODIESEL can/will leave some very nasty residue that will clog lots of fuel/injector parts.... |
