![]() | Home > Technical (L322) > Driver side window washer inoperative |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
The washer jet incorporates a small non-return valve in the body behind the jets.
| tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283
They are heated. See if you are getting water to the inlet and if so then the jet is still clearly blocked.
| Fowey Member Since: 15 Oct 2012 Location: Lincolnshire Posts: 13
Thanks fellas, I will remove the jet tomorrow in daylight and check out the plunger etc and let you know the outcome.
Thats interesting as my old man said that when they were using range rovers and discoveries during Rover/BMW testing in cold climates they would routinely remove the non return valves as it was the weak point with regards freezing and damaging the plunger/membrane. Trouble is when you do it at the rear it takes a while to come through by which time your wiper has been rubbing grit and mud onto your window but I dont imagine this is much of an issue at the front especially if the other one is fine. Out of interest do you see a difference in the speed the water appears between the two jets?
Surprisingly the jet works as before, although as you say you would expect the water to drain back, to date mine hasn't.
| RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648
Literally just fixed my 2012/12 Westminster d/s washer jet.Unclip it,remove red/orange rubber plunger,refit,done!
