![]() | Home > Maintenance & Mods (L322) > Flat battery issues |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3927 ![]() ![]() ![]() |
I had a thought |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
I had heard that it checks its level every Xmins. However i was subsequently told that it does go into a 'sleep' mode.
It will re check every now and again |
Leaving on bump stops? Is that the same as leaving in access mode or is there something new for me to discover? Geoff |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
bump stops are slightly lower than access...normally goes to this if you've had it jacked up [repairs etc] and then let it down.. ... - .- -.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
After I have jacked it up, it stays there, higher than off road, until I start driving it.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
or take a booster pack/second battery.
I would disconnect the battery -ve terminal when you park the car and accept you have to open it with the key before re-connecting battery. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
Solar charger ? |
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 ![]() ![]() ![]() |
Thought relevel when parked up was: after last door is closed, then every 6 hours...
No it will use up what's in the reserve then start the balancing act bleeding the system to equalise it until its drained. The control valve isn't too powerful but its constant kick in and out will have that affect on any battery |
I think some of the things in those documents have either been changed with updates or were just bs to start with though |
