Home > Technical (L322) > Possible Injector Failure |
Don't you dare! Its bad enough its likely to be the one at the flywheel end
9th Feb 2013 7:28pm |
Well the injector is now soaking in a mix of GT85 and WD40 and BioD
10th Feb 2013 2:38pm |
PS CTC is this the kind of thing you have??
10th Feb 2013 2:41pm |
I'll have to get it warm now which means re-attaching half the stuff i took off
10th Feb 2013 2:49pm |
And some documents i found to help future peeps
11th Feb 2013 12:35pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Hi Kingpleb, one further thing to check whilst you're at it. I got rough running and car wouldn't do over 30mph about a year ago (thread http://www.fullfatrr.com/forum/topic10722.html?highlight=fuel refers) and though it was a fuel injector, but turned out to be corroded contacts on the fuel injector wiring loom (@£60 part ) so may be worth you doing a continuity test on the wiring loom contacts if you've removed it. Steve
11th Feb 2013 5:24pm |
Checked the loom out and the connectors all look fine takes a while to look with a torch and a floodlight but all done
22nd Feb 2013 8:26pm |
http://www.bimmerforums.co.uk/forum/f89/ch...s-t124159/
22nd Feb 2013 8:35pm |
Ah well, was worth checking the loom anyway as it would have been the cheapest fix if found to be the problem. Good luck Kingpleb Steve
25th Feb 2013 3:37pm |
Well been let down totally by the plank who said he would be able to come round yesterday after days of waiting for a callback and then said he was too busy to do it as promised but would be able to (again!) possibly come by midweek. Just told him to call me when he is free as i know he won't do as he doesn't return calls now!
25th Feb 2013 4:19pm |
FOR SAKE!!
2nd Mar 2013 11:48am |
Sending the tool back today.
4th Mar 2013 10:17am |
Well good news!
4th Mar 2013 3:41pm |
Well Injectors replaced and after a quick run while the engine is smoother the issue is still there
5th Mar 2013 6:17pm |
