Home > Technical (L322) > RetroFit Factory Phone
Page 2 of 3 <123>
Ivan
Ireland 2005 Range Rover Vogue SE Supercharged Zermatt Silver
I have to agree, I put an e-bay Parrot into my other car and it lets me access phone book etc. All for the princly sum of £50 and an hours work! It's only drawback, like any B/T set-up is no external antenna for the phone, though many newer phones have no facility to connect one
Ivan FF RR S/C (Gone)
TVR Chimaera 500(Gone)
TR7 V8
Post #6820 10th Aug 2009 9:51am
I'm sure it would not be hard to wire one up though, Dan sounds a man with many talents! Discovery 4 HSE
1993 90 Tdi
Post #6822 10th Aug 2009 9:53am
Andy
RRUK wrote:
plus it transfers the phonebook too, the LR one does NOT! Evil or Very Mad
According to this video, the BMW one does
&eurl=http%3A%2F%2Fwww%2Eroverupgrades%2Ecom%2FRange%5FRover%5FBluetooth%5FRetrofit%5FKit%2Ehtml&feature=player_embedded 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #6829 10th Aug 2009 10:54am
dan_uk_1984
I already have the Nokia Bluetooth kit, it has a small button with jog wheel, about the size of a 10p but this is too intrusive and not as god intended my dash to be! The thought of installing a parrot to my dash makes me want to vomit quite frankly with its massive lurid backlit display, I could just cut my eyes out I suppose instead…. Bit OTT I know, but you get the picture!
Integrated & hidden is where it's at! The parrot doesn’t allow you to use the steering wheel controls, or read texts on the main display, or link your phone address book into the nav....
Post #6830 10th Aug 2009 11:00am
Since when did the RR system allow you to read texts (only if crappy old phone in a cradle) or link address book to the nav? Discovery 4 HSE
1993 90 Tdi
Post #6832 10th Aug 2009 1:05pm
dan_uk_1984
"Remote sim mode" on the phone enables the address book sharing... As far as Texts are concerned I dont know how it works, I presume magic. But it's a feature it discusses in the manual none the less.
Obviously you can buy different clip-ins for different phones or if you have a phone without a pop port connection you have to go bluetooth
Post #6835 10th Aug 2009 1:27pm
I might have misunderstood...I thought you meant it took details from your phone's address book i.e. Name and address and used them to plot a route.
What you mean is just reading texts on screen. I've done that, and used the touchscreen keyboard to type out a text, shame it only works when you have a phone in a cradle. Discovery 4 HSE
1993 90 Tdi
Post #6842 10th Aug 2009 2:56pm
dan_uk_1984
I'm sure I read that it will integrate with Vcard equiv' on the phone. It should also work via bluetooth. I'm talking about the Pre Touch screen setup if that makes a diff?
Of course I might be making it all up!
Post #6845 10th Aug 2009 3:12pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Txt / phone book does not work via bluetooth, yet. There is a software upgrade, £100, to allow you do this, but it is not guaranteed to work. Acording to my dealer.
Post #6850 10th Aug 2009 4:03pm
Larry
England 2006 Range Rover SE Td6 Java Black
Is that just that it isn't tested for many phones, or is it a bit hit and miss? Would be interesting to know which phones the upgrade will work with.
Surely wouldn't be beyond sense for a dealer to upgrade one of their demonstrators and let customers pair with it to see if their phone worked or not.
£100 isn't cheap, but by the time you've bought the right cradle etc for the phone (and in my case a phone that fits it), you're probably in that terriatory anyway, and still have the down sides of the phone in a cradle (I'm assuming that the options are a)use the cradled phone as a dedicated "car phone", b)remember to forward your regular mobile to the cradled phone while you're driving c)use the mobile and fit it in the cradle every time you get in the car).
Personally I like just getting in the car with the phone in my pocket and not needing to do anything (I can live without the phonebook and texting from the screen seems daft when it's less effort to just take phone out and use that!
Dan, could you not rewire the Nokia bluetooth button to you wheel buttons (I'm sure it won't be that simple!)
Post #6859 10th Aug 2009 5:02pm
nbunney
Larry
Totaly agreee with stealers getting a demo, bit I am led to believe that it is hit and miss if it works on eac upgrade.
I will be asking them again how things are going at the end of Aug.
Post #6871 10th Aug 2009 9:14pm
Liszt
2004 Range Rover Vogue 4.4 V8 Buckingham Blue
noddy wrote:
Yes. Bluetooth antenna is about £15 on eBay. Mic is £14 from BMW. I've compiled a list of all the required parts and part numbers, which I'll PM to you.
Hi Noddy,
I have just got a 2004 and would love to fit the bluetooth stuff. do you still have a list of the bits needed?
Cheers.
Liszt
Post #17156 22nd Apr 2010 11:18am
Shaun the Sheep
England 2007 Range Rover Vogue TDV8 Stornoway Grey
RRUK wrote:
As the original PTI didn't allow for modern phones in the cradles and the bluetooth wasn't standard (I think?) would you not be better off installing a Parrot kit? My mate has one in his M3 (even tho the M3 has BT) and says its brilliant, plus it transfers the phonebook too, the LR one does NOT! Evil or Very Mad
a software upgrade see to the phonebook transfer, had it done the other week, cost 1 hours labour from the main stealer. I use a HTC Touch HD
Post #17162 22nd Apr 2010 12:24pm
Liszt
So,
Been doing some digging and think these are the bits I need. Can anyone confirm this?
BMW Microphone 84 31 6 938 762
BMW Bluetooth Module 84 10 9 154 358
BT Ariel ??
LR cubby box trim Part Number FJB000130PVA
BMW Iphone Snap in adapter 84 21 2 158 682
Landrover Wiring Loom YMQ 002340 Repinned (l322.com)
Steering wheel talk button unit??
Cheers,
Liszt
Post #17280 23rd Apr 2010 11:41am
Mapmuppet
Dan, for 16K you can have my factory fitted phone and I'll even throw in a FFRR Very Happy 2005 Audi A8 W12
1978 Mercedes 450 SEL 6.9
1986 Mercedes 420 SL 4.2
Post #17282 23rd Apr 2010 12:08pm
Page 2 of 3 <123>
