Home > Technical (L322) > self leveling headlamps on 2010 conversion
klf400
has anyone managed to wire uo the self leveling headlamps on 2010 conversion as per the old 2002-2005 headlamps , the old headlamps had an extra multi plug which i guess is for the self leveling { this being xenon headlamps } , i cant recall seeing any threads regarding this , not unless the 2010 headlamp has this feature built in as there are 3 ecu"s on the headlamps that may sort this out, but i am not so sure 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #171563 11th Feb 2013 9:30pm
You shouldn't need to as the car does the self levelling and not the lights Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #171572 11th Feb 2013 10:53pm
Googsy
I think new loom is required when moving from 03 to 2010 setup in any case. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #171573 11th Feb 2013 10:56pm
Re: self leveling headlamps on 2010 conversion
No they won't work as it's a different system Thumbs Up
Post #171602 12th Feb 2013 1:27am
klf400
cheers craig , you have put the tin hat on it ,lols Thumbs Up 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #171813 12th Feb 2013 7:48pm
Tin hat on it???????
Post #171861 12th Feb 2013 10:07pm
daveo
To put the tin hat on something is to finish it off or bring it to an end. V8 facelift Range Rover Autobiography 22" wheels.
Post #171900 13th Feb 2013 12:24am
Ahh, thanks Dave Thumbs Up
Post #171902 13th Feb 2013 2:15am
