Home > Maintenance & Mods (L322) > Changing green interior LED's
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
Having way too much time on my hands I jokingly mentioned changing every green interior LED to a white one. I know you can get the dash done for upwards of £150 whilst having the dead pixel display fixed. I have played about with this type of stuff before but never on this scale.
I'm just wondering if anyone else has gone down this road, I have a few bits & bobs to practice on and luckily the RR is very easy to take apart and put back together again. My only worry is the RR has more internal illumination than the starship enterprise so once one starts, there is no going back Razz
Post #171659 12th Feb 2013 12:13pm
The hardest part will be getting LED's that are not to bright or to dim, which is a personal thing i guess. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #171663 12th Feb 2013 12:24pm
SteveyD
I think your right, trial and error to match what's already fitted. Modern LED's are always very bright even with a reduced voltage. It might be easier to change the resistance values of the dimming switch. Well iv found something to occupy myself today, the MOT on my other car expires tomorrow so off for a test I go Whistle
Post #171665 12th Feb 2013 12:34pm
by green i gather you mean the yelowish ones ...i just changed the 2 overhead lights to smd's and that was enough... ... - .- -.
Post #171669 12th Feb 2013 12:39pm
SteveyD
No I'd actually leave the yellow ones (suspension/heated seats) I mean anything that lights up green inside once the external lights are turned on. That said do they already emit white but each switch has a green diffuser?
Post #171674 12th Feb 2013 12:44pm
not sure , probably a diffuser like you've suggested.. ... - .- -.
Post #171675 12th Feb 2013 12:46pm
SteveyD
I'll plug a spare pcb in and investigate further.
Post #171680 12th Feb 2013 12:56pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I think you'll find they are actually green LED's - not white ones with a diffuser Sad
Also, changing the resistance of the dimmer the alter the brightness of replacements isn't that simple - the dimmer just sends a signal to the light control module to tell it to reduce the brightness of the LEDS...
Post #171700 12th Feb 2013 1:33pm
SteveyD
I think they are green too, that's perfect. I'll have a look on RAVE for schematics regarding that control module. In theory it should still be resistance dependent. I know a good electronics company that could identify the values of the green LEDs and offer a similar matched value.
Post #171717 12th Feb 2013 2:31pm
Someone on here did change all their dash leds to white when they had their pixels done. Do a search on "pixels", there were photos too Thumbs Up .
Post #171754 12th Feb 2013 4:55pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
I have been thinking about this for quite a long time too, the dash is the easyest bit to do i think, but the touch screen will be the worst!
I have been thinking a light blue with red heater and hight lights.
It is goining to be a massive undertaking but i think it is the best way to update the feel of the interior.
Im not set on blue and red (i suppose i could have just bought a VW Shocked )
Post #171774 12th Feb 2013 5:42pm
daveo
this is what you are up against,
they are the same in the touch screen, i do have some pics of the boards as well,
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #171819 12th Feb 2013 8:08pm
SteveyD
Barracuda my other car is a golf so that must be where it came from Smile
Dave, thanks for the pics. The LED's are a straight forward job. It just takes a steady hand and making sure the polarity is the right way around. Is that the heater switch? I think I'll practice on my old clock panel and post my results before & after. and go from there.
As for touch screen I'm not fortunate enough to own one (yet) but I'm sure as you say it's going to be a similar job.
Post #171967 13th Feb 2013 1:00pm
I noticed the other night that the left hand temp dial is a fair bit dimmer that the right hand side, so I wonder if this is repairable by replacing the control board with the LEDs on it? Got - 2017 SDV8 Autobiography in Loire Blue
Post #175146 1st Mar 2013 10:56am
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
Typically, the resistance of the "dimmer" is used in the PWM circuit to determine pulse width.
You don't dim LEDs using a resistor, you dim them by sending pulses of full voltage; the wider the pulses, the brighter the LED appears.
Pulse Width Modulation.
Otherwise, you have to dump the heat generated by the variable resistor.
Old school. Jim
2000 NAS HSE
2005 NAS HSE
Post #175335 1st Mar 2013 11:59pm
