![]() | Home > Technical (L322) > engine check light not coming on |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Could be that some unscrupulous toerag has covered the LED inside the pod because it is illuminated all the time, or more likely it could be that there is a fault in the wiring from the ECU to the lamp. |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
I can't be sure but I remember that you can turn it off with a Faultmate (so probably also with some others). I have considered it on mine due to the bad quality fuel issues on mine throwing the light all the time. MY 2010 5.0 SC Galway green and sand interior!!
| RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85
Did you ever find the cause of this problem Swiftman? Just found out I too have this issue on same model year as yours. 2012 Westminster TDV8 4.4 Indus Silver
Okay, I'm confused now! Owners manual states it should do a bulb check at startup but RAVE suggests it should not? The only reason I noticed mine not lighting was due to having the injector wiring loom failure issue causing a severe misfire last week and generating a fault code which I assumed should also throw up the check engine light? Tried to force a bulb check with IID tool today but it seems to be one of a few instrument cluster bulbs not listed in the available IID menu tests. 2012 Westminster TDV8 4.4 Indus Silver
| All times are GMT |
