Home > In Car Electronics (L322) > benifits of having an intravee
klf400
anyone help with the plus and minus points of installing an intravee ? also will it work with my cd changer and will i need any other items for it to work ? my digital tv tuner works on my av channel so i am a little puzzeled what to do Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #168928 30th Jan 2013 9:49pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
The intravee plugs in place of your CD changer you can run up to 3 devices but why would you, all your music can go on an Ipod so why would you want a MP3 changer as well, you can also set up mirror folding 9even set the amount of time they take to fold) auto locking, and the nav screen will show the actual distance to impact when the PDC's are activated, I love mine. You need a seperate box to plug the ipod into, plenty on ebay. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #168984 30th Jan 2013 10:46pm
ccfj1
1st post, so hello.
You can run multiple devices actually, I have 2x ipods, 1x iphone 1x dab and 1x dsp and the all work perfectly together.
Quote:
you can also set up mirror folding (even set the amount of time they take to fold) auto locking, and the nav screen will show the actual distance to impact when the PDC's are activated, I love mine. You need a seperate box to plug the ipod into, plenty on ebay.
There are other functions too, its a great piece of kit, I love mine.
Post #172292 14th Feb 2013 4:14pm
Britishlion
Hi
Does it only work on specific models or all ?
Post #172473 15th Feb 2013 1:29pm
ccfj1
Anything that uses an i-bus. AFAIK
Post #172474 15th Feb 2013 1:29pm
Britishlion
Confused I-bus ?
I have a 2005 touchscreen system ? is that not the same I'm guessing.
Sorry for the newbee (thick) questions
Post #172475 15th Feb 2013 1:52pm
ccfj1
I-bus the network used on some cars so that data can be passed along the system so that devices can communicate with each other.
I-bus is higher form devices, such as Navigation, phone, cd changer, dsp, screen etc...
K-bus is a lower form for things like electric seats, AC, pdc, cluster etc.
Touch screen is not compatible with the Intravee AFAIK, but someone will correct that if the know different.
P.S I'm a newbie myself.
Post #172477 15th Feb 2013 2:04pm
fraid not BL touchscreens are harder Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #172478 15th Feb 2013 2:11pm
Britishlion
Crying or Very sad
Post #172577 15th Feb 2013 11:31pm
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
Anyone fitted this to the 2003 Vogue? Do I require all of this for iPhone?
Intravee ii @£151
Alpine KCA 420 @ £100
Long AiNet cable @ £26
Dice DSP Adapter @ £68 ( I'm assuming this as I have the Vogue and DSP amp)
Total @ £345
TBH that doesn't sound that bad, but if I don't need all of that, every little helps. Bushy
2003 RR Vogue Monté Carlo Blue
Post #174923 28th Feb 2013 12:32am
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
No need for the Dice - the Intravee takes the place of the CD changer in your glovebox (as mentioned above somewhere). Keep looking on ebay. There's frequently a used combined Intravee/KCA/AiNet cable package in auctions. The average rate seems to be £190 to £210 for the auctions, although at times there are bargains to be had (like when I got mine for a buy it now of £65!).
Post #174925 28th Feb 2013 7:37am
chris_read
Oh I forgot - you'll need a 12V to 5V adapter to charge an iphone from the intravee connection. I paid £7.99 for mine.
Post #174927 28th Feb 2013 7:38am
RichardP
You don't need the long cable or DSP adapter in a FFRR, so just
Intravee ii @£151
Charge Converter @ £10 (ony if using later iPhone, iPod Touch, iPad or Nano).
Post #175251 1st Mar 2013 7:31pm
Bushy513
Thanks for the help guys I'll have a look on eBay. Bushy
Post #181613 7th Apr 2013 7:42am
