Home > Technical (L322) > Air Suspension - Problem ?
Britishlion
Hi,
So a while ago i noticed the car sitting lower on the back than the front, never thought much of it if I'm honest,as i remember reading on here there is a difference , but now started to feel the car wallow ? don't know if it is to do with suspension or not ?
But today was showing my detailing friend how to drop the height and lock in access etc, went from access to normal and must have taken two minutes before the light came on to say was in position correctly
very strange
any ideas anyone what my new problem might be ?
Post #172571 15th Feb 2013 11:25pm
If it was just after startup maybe it was taking its time to build pressure back up in the tank Smile
Only other thing it could be is a compressor issue.
If it sinks when parke up though it sounds like a leaky bag or pipe somewhere at the rear Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #172591 16th Feb 2013 12:19am
Leave the car running for a good 10/15mins on normal height (to top up the air) then put it into offroad height and see if the car will achieve that height?
Stand outside the car and listen for leaks... If it does achieve offroad height quickly then gently lift the rear arches by standing with your backside against the wheelarch and lifting, listen for leaks... Might be worth checking the fronts too Thumbs Up
Most FF's with a holed bag wont achieve full height as they loose too much air trying...
Craig Thumbs Up
Post #172594 16th Feb 2013 12:51am
Britishlion
Thanks
I will try this when i get it back from detailer !
Post #172645 16th Feb 2013 12:21pm
