![]() | Home > Technical (L322) > Rear wiper not working -rear fuse box query |
Are you sure it's not just a fuse that's blown? |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 ![]() ![]() ![]() |
I checked the fuse and ok. In fact I checked every fuse in the back as the numbering was nt clear. I will put a multi meter on the fuse tonight. I was struggling to understand how a fuse box can fail and without removing it I am not sure who its constructed. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35749 ![]() ![]() |
i'd put the multimeter on the motor side to see if that is getting current.. ... - .- -.
The good news is the rear wiper is nothing to do with the front wipers which are controlled by the BCU.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Not clear what car you have 666tur (please add to profile), but the '02-'05 handbook indicates that Fuse 80 on the rear fuse box is for the Rear Wash/Wipe, rated 20amps. .
When you hear of instances like this you can only despair at the low level of technical ability of staff in some Dealerships. |
Thanks. It's an 04. I'll be out after top gear to investigate with my multi meter! 2012 4.4TDV8 VSE
Have you checked Fuse 41, 5A on the front fuseboard? |
No I have nt. manual referred to rear fuse box. I will investigate. Thanks 2012 4.4TDV8 VSE
Checked fuse 41 and fine
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 ![]() ![]() ![]() |
I have a similar issue. My rear wiper and wash packed up ages ago. It's not any of the fuses, and its not the motor spindle issue, as I have test fitted a brand new unit and still nothing. Got a constant 12v on the power plug to the motor unit too.
alexpez23 Member Since: 01 Apr 2013 Location: Shropshire Posts: 20 ![]() ![]() ![]() |
Did you ever cure this problem? because i have an 04 rr vogue and the rear wiper and jets dont work either |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
I can see it now, someone takes their car in because the keyfob battery is dead "Well sir after extensive diagnosis we have found the signal is not getting from your fob to the car so we recommend you purchase a new car and keyfob" I honestly cant imagine how they keep a straight face sometimes. |
if you look in our wiki you'll find the info you need to sort this out.. ... - .- -. Y. O. L. O. . |
