Home > Technical (L322) > Rear Wash/Wipe - One-Way Valve?
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Does anyone know the location of the one-way valve for the rear screen washer in a 2008 TDV8 Vogue?
It's now taking forever to get screen wash onto the rear screen - the (useless) dealer is saying there is no problem and it's due to the washer reservoir being in the front. Rolling Eyes
There are no obvious leaks (e.g. down the inside of the rear screen).
Thanks in advance ...
Post #17290 23rd Apr 2010 2:08pm
It all enclosed inside the motor, it's a one piece unit.
The first thing to do is check the jets not blocked with a pin. If no improvements and you are certain there's not a leaking hose behind the top tailgate trim, then I'd suggest a new motor. I replaced mine when it finally gave in but it was always a weak wash on the rear screen.
Replacement is easy though, I did a How To thread on it. Discovery 4 HSE
1993 90 Tdi
Post #17306 23rd Apr 2010 4:07pm
Philip
Thanks - it's definitely not a blocked nozzle as it does eventually work as it should if you keep the stalk pushed for long enough. Will investigate further for hidden leaks.
Good How-to, but I expect the warranty to sort it.
Post #17310 23rd Apr 2010 4:20pm
Andy
I'm not getting any water to my rear screen. The motor sounds like its running intermittently when held? Sort of a stop/start. The front is fine.
Any suggestions? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #17311 23rd Apr 2010 4:22pm
SGW
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
On my 02 the inline non return valve is adjacent to the motor, when I replaced it a couple of years ago it was about £2.00. If on the later models it is integral to the motor you could cut the tube and use an inline one.
Cheaper than a new motor.
Stewart.
Post #17357 23rd Apr 2010 10:02pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
On a related note.....
how do you get the rear wiper to move to the half way position in a car with keyless entry and ignition so you can check the blade and unblock the nozzle?
If you start the wiper then switch off the engine the wiper continues to park itself off screen. I suppose I could pull the fuse but is there an easy way?
T
Post #457149 13th Nov 2017 5:40pm
nino_nino
when the wiper starts to go down open the rear gate. it will stop the wiper arm. it will take some practice to get it right. Very Happy
Post #457150 13th Nov 2017 5:57pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Non return valve is situated just to the left of the wiper motor! It is not part of the wiper motor!! 2014 vogue se
Post #457159 13th Nov 2017 7:01pm
Clabs
Great tip Nino - thank you Very Happy
Post #457180 13th Nov 2017 10:01pm
tomthevet
Cheers for the tip!
All unblocked though blooming airlock I think. Never had a car that gets as dirty up the back!
T
Post #457465 16th Nov 2017 10:12am
