![]() | Home > General > Soon to be new FFRR owner with questions |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
http://portal.jeengineering.co.uk/engines/diesel-tunes.html
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 794 ![]() ![]() ![]() |
Booked my 4.4 TDV8 in at JE for their re-map on Wed |
campaj1 Member Since: 22 Oct 2012 Location: Cheshire Posts: 729 ![]() ![]() |
brilliant, will be great to hear about the results! |
mikef Member Since: 30 Jan 2013 Location: Bucks Posts: 82 ![]() ![]() ![]() |
Yup, I'd be very interested in hearing what difference it makes to the performance and the fuel consumption because in my experience, remaps do improve fuel consumption too |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
Ipanema Sand is a very nice colour |
Probably should start a new thread (sorry OP).
Thanks, Phil |
mikef
Thats v impressive. 10% improvement is more than I've seen on the various turbo diesel BM, Merc and Audi remaps I've done in the past. Sounds like its well worth it. Do JE say anything about how detectable the remap is by L-R diagnostic tools? |
They were very careful when opening the ECU and have reasealed it so it is difficult to tell it has been opend. No discussion regarding diagnostic tools but a dealer would notice it if they drove it ![]() On my 7th RR plus various other JLR vehicles |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 556 ![]() ![]() |
Sounds like the carpet has been wet vacced and then the car has been sat doing nothing, hence getting cold. However check the sunroof drain tubes. These sometimes block and can cause water to enter the footwells as there is no escape. I know of dealers who do the quick fix by removing the non return valve in the drain tube, as it drains down near the wheel arch somewhere. Worth also checking the window door seal. Make sure it hasn't been pinched.
Thanks Big Boy R44ROV for the heads up on the leak. I think you may be right on the wet vac because after a few weeks of use, I'm noticing the misted up windows less and less. However I am starting to learn about the little foibles of FFRR ownership already; it's definitely not like owning a German car and I mean that in a good way as well as a bad way. Yes, after 2000 miles, the apparently new Contis fitted by the dealer are already showing signs of wear and it won't be too long before I have to bin them. My car is still under the manufacturer's warranty. Does anyone know whether fitting tyres that were not original fit would void the warranty in any way? I'm thinking that if, by chance, I get any kind of suspension issue, the dealer might try to deny the claim by saying I had fitted non standard tyres.
Hello mikef.
Yes you're absolutely right. The FFRR is about the most soothing car I've ever owned; it is definitely one of those cars that make you feel good about driving it and I suppose that is why people keep buying them |
