![]() | Home > Technical (L322) > TD6 water pump change |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
There's a web based version of rave in the wiki. iPad friendly! |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
I think the part number is PEB000050G |
| 666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108
Thanks
I would think the radiator would need to come out to allow access as it's rather tight in there |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
To get at coolant pump looks like same procedure as thermostat, apart from the need to remove the ancillaries belt
Thanks for the help.
Done some more research. The plastic impeller had fallen off as I took the pump of, the metal is from the bearing. 2012 4.4TDV8 VSE
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
If it were me I'd flush the system in both directions and leave it a good 10 minutes each way to do it. Also take the chance to flush your rad out and get any gunk from the bottom out.
Thanks. I have been running a hose through every easily removable pipe to clear what I can. I intend to run it up to temp with water and drain down again before adding antifreeze.
The problem is you do need a skinny spanner to fit on the back "holding nut", and you are right, the Halfords fan spanner is just not long enough to get purchase. I bought a proper 32mm (monster) for the nut on the fan.
Our advice then to others is get a decent 32mm spanner, I went into halfords originally to see if they had any. They said they only stock up to 19mm, then the lady said he'd check. She came back saying they had a 33mm one!!
Interesting, on mine, the "fan nut" was 32mm and oil filter cover 35mm ? .
| All times are GMT |
