![]() | Home > Maintenance & Mods (L322) > *** 2010 in car pc project UPDATE *** |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
I am a big fan of the Asus EEEPC range of nettops (daily use)
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8059 ![]() ![]() ![]() |
You'd need some sort of momentary relay for the power on. wired to ignition live, to replace the PC power on switch.
The largest selection of DC-DC power supplies and start up / shut down controllers AFAIK is the MP3car.com shop. Did you want to avoid ordering from the US?
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
Matt, I've got an asus eeeeepc hardly used if you are interested. Pm me if so. |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
Hi mate, i have a asus eee pc laptop already i am more thinking an asus eee box might be the way forward if i can find a suitable way to power it automatically. matt |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Matt
hi matt,
ok after an entire day of researching and looking for ideas of using an asus eee box then contemplated on building a custom mini-itx machine the answer has been staring me right in the face all along |
ok so i have spent the day installing windows 7 and the range rover software on to the PC i will be using in the car, and as always have hit a bit of a stumbling block |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
I certainly can't add anything of a technical nature, so will make do with posting to show my support - a great project, looks like you can achieve some really useful functionality, keep going Matt! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
matt, i stopped the project due to the problems with the switches,have you overcome this, |
Hi Dave, not overcome it yet - but i have found a little more info on the ardunio my plan to start with is to just get some standard buttons to work (not using the factory circuit board to start with) then once the software works with the standard buttons i will know the code works and i will try again to get the factory circuit boards to work.
here is my board, its a 2.2ghz with 1gig of ram, it is only 200mm by 200mm with one pci slot for the camera card,it has a full size atx plug so no probs with my car pc power supply
davetrees Member Since: 01 Dec 2009 Location: Sunshine Coast Posts: 5 ![]() ![]() ![]() |
daveo did you have any luck with the arduino chip I sent you? |
