Home > In Car Electronics (L322) > Sat Nav Power Light
Saltyfish
England 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Sat Nav Power Light
Hi all
i have a 04 vogue with a minor power drain, if left for more than 36hrs the battery goes flat. I have replaced battery but no change, earlier tonight i noticed the sat nav power light stays on after the car has entered sleep mode.
To eliminate this is the cause can anybody confirm if the sat nav power light should be on or off when the car is in sleep mode.
Thanks in advance.
Post #173658 20th Feb 2013 10:00pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
When you say sat nav light
I take it you mean the cd drive in the boot
Is it a mk3,
They should shut down after about 3 mins
After taking the key out or shutting the last door RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #173673 20th Feb 2013 11:14pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Remember reading somewhere that a 'design flaw' of shutting the boot as the last door shut meant the sat nav remained powered on.
Post #173687 20th Feb 2013 11:58pm
Saltyfish
Many thanks for the reply's, the nav unit is a MK3 and the red power light on the cd drive stays on after the driver door has been shut. The car enters sleep mode (gear selector light off) but the nav drive power light stays on, hope this clarifies things. Thumbs Up
Regards
Tim
Post #173698 21st Feb 2013 5:32am
klf400
are you noting the sat nav light being on by looking through tailgate glass with the parcel shelf folded forward and the cover removed when the car is asleep as this is the only way to see if it shuts down , because as soon as you open a door or unlock etc the sat nav will power up Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #173798 21st Feb 2013 6:59pm
Saltyfish
Yes KLF400 thats exactly how im checking it ive even made sure the drivers door is the last i shut. Wink
Post #173826 21st Feb 2013 9:11pm
I'll roll out the old favourite as a starter: battery disconnection procedure.
If that doesn't work may be worth getting in touch with Baris, to see if he can check the unit over for faults etc. .
Post #173828 21st Feb 2013 9:19pm
You could just remove Fuse 49 and leave the car for a while.
If the battery doesn't go flat the sat nav is probably your problem.
To double check replace fuse 49 and un-plug sat nav unit.
If the battery still doesn't go flat, your sat nav is not shutting down correctly hence the battery drain.
Post #173829 21st Feb 2013 9:27pm
Saltyfish
Very Happy Ok so ive unplugged the Sat Nav and everything appears to be fine, so its probably the Sat Nav not shutting down.
Where does the Sat Nav get the signal from to power down?? If its in the unit itself then i'll replace but if its elsewhere then i'll have to investigate further.
Thanks.
Post #174769 27th Feb 2013 5:21am
