![]() | Home > Technical (L322) > ignition lock slow |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
I found mine was slow when the battery hadn't been charged / topped up for a while
RichTDV8 Member Since: 16 May 2010 Location: Berkshire Posts: 57 ![]() ![]() ![]() |
thanks SB it definitely only happens when left for a few days Previous
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
my battery started feeling low on power only after about 10 months, mainly cos i didnt use it very much, as said above charge it up or get a replacement. ... - .- -.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
Mine did the same, and now it doesn't work at all! TBH I don't care, as I know if I investigate it the dealers will tell me it's a new steering motor or something that will cost me a fortune. Discovery 4 HSE
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Get the automatic in/out with ignition cycle turned off via diagnostics... Will also save the life of the motors too |
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 ![]() ![]() ![]() |
Know this is an old thread but I have same problem with ignition lock slow to respond when key inserted, this was after a hard battery reset, I am aware steering column movement can be removed but post from Craig seems to suggest ignition lock can be coded out, if so can it be done with IID tool ? |
