Home > Technical (L322) > HEADLAMPS stop working every 20 seconds ??
In the hope of removing all doubt:
Post #174097 23rd Feb 2013 8:07pm
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
HI JOE90; thanks for the drawing, hopefully as you say, it should remove all doubt. i doubt there is anything i can check on it?, so assume it would need to go on diagnostic?
in the meantime i will get some prices for a new one. i hope it doesent cost as much as it looks like it might cost, Whistle Whistle Question Question Question
Post #174166 24th Feb 2013 10:35am
Try the battery disconnection / ECU clear routine first. .
Post #174187 24th Feb 2013 12:58pm
BOBCUSSEN
HI JOE
i have carried out the battery disconnect etc and still the same. as a matter of interest, i removed the red twist plugs one at a time from the two dipped beam lamps ( one at a time ). just to see if one lamp was causing the problem with the rest Exclamation Exclamation , probably wishfull thinking, anyway all that happened was i got the usual fault chime and then the check dip lamp signal on the dash board..
so i have yet to look at the LCM
BOB
Post #174245 24th Feb 2013 4:35pm
BOBCUSSEN
whilst i am trying to get to the bottom of this stupid glitch with the headlamps going out every 20 seconds Censored Censored Censored Censored Censored Censored Censored Censored Censored Censored Censored Banging Head Banging Head Banging Head Banging Head Banging Head Banging Head Banging Head which means the car cannot be used after dark Exclamation Exclamation Exclamation Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Censored
if the smaller of the two lamps is dip/main and the larger of the two is main / high Question Question should they both come on, on dip beam Question or just the little ones Question
Thumbs Up bob
Post #174320 24th Feb 2013 8:19pm
BOBCUSSEN
i would imagine that was a stupid question in as much that only the small one is called the dip/main, but i thought i would double check then probably just shut up making silly comments Embarassed Whistle Thumbs Up
bob
Post #174322 24th Feb 2013 8:27pm
fyi, the outside lights are dual purpose...they are dip and main by using a shutter in front of the bulb....the inner lights are just for flashing and for main as well but they are not very bright.. ... - .- -.
Post #174324 24th Feb 2013 8:30pm
BOBCUSSEN
hi stan, thanks for your reply;
so it is the little ones that has the shutter then Question . when the lights go out, i can hear a clunk noise when they come back on, so i assume that is the ballast thingy Question Question Question .
if indeed it turns out to be a fault with the LCM, can i just fit it or does it need to be programmed at the dealers Question Question
Post #174329 24th Feb 2013 8:37pm
