![]() | Home > In Car Electronics (L322) > Intermittent "Phone not Fitted" |
What model of phone do you have |
jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308 ![]() ![]() |
Hi,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35811 ![]() ![]() |
to many paired phones on the system maybe.. ... - .- -.
The system does not exist when it happens. No options at all, just "phone not fitted'
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3942 ![]() ![]() ![]() |
I get this all the time, quickest fix I find is to go the the off road screen and select the camera it realises it isn't that you want, as its tucked away in the glove box, and bingo the phone reappears. Geoff |
Will give that a go, thanks 2011 Stornaway Grey 5.0SC Autobiography |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
When you use the "venture cam" it comes up with "Phone not fitted" i would first remove the camera from the equation...
Don't have a venture cam at all, so cant't be that. 2011 Stornaway Grey 5.0SC Autobiography |
i'm suggesting my favourite solution, the battery....could it be the battery power is not enough to get all the ecu's sparking up and the bluetooth one gets excluded . ... - .- -.
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
i got the same issue from time to time - i take my phone in my hands and call someone and ops it reappears fitted...... |
Hope it's not the battery as it has been replaced (along with the alternator) in recent weeks......... however I accept that past performance is no guarantee |
m3mjw Member Since: 10 Feb 2012 Location: Sunderland Posts: 118 ![]() ![]() ![]() |
Mine does this all the time and seems to be no reason for it. I had all of the software updated, it worked for a while and then again back to square one. I unpair it every now and again and re pair and that works for a while. If anyone can come up with a more technical fix i am all ears L405 4.4 SDV8 Santorini/Black VSE
McSchotte Member Since: 21 Jan 2013 Location: Cologne Posts: 5 ![]() ![]() ![]() |
After working perfectly for a month mine suddenly started doing this too. It disconnects every few of minutes and when it re-connects it causes the audio to drop out for a couple of seconds which is annoying the hell out me. The only thing I can think of as a cause is a firmware update I did on my iPhone 5. I'll test it with my wife's iPhone 4 and see if that's ok.
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 412 ![]() ![]() ![]() |
Don't fully know if that is the case, but I think i've worked out the logic of why sometimes it doesn't work.
