Home > Technical (L322) > headlamp failier whilst under speed at night
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
yes if just dip are on o there own, they both go out it i put the lever to main beam, the other ones come on as well and again after 17 sec they all go off at the same time for 2/3 sec then all come on again.
i did take the connection of the back of the little ones, one at a time the put the lights on, and the same happened to the light that was still connected, still went out after 17 secs. however as each light was dis connected, i had the chime and the dash board reading telling me to check the lamp etc so that bit works ok
Post #174569 25th Feb 2013 9:48pm
BOBCUSSEN
hi joe, i would if i were in uk, but i will get a total rip off here in france im afraid. they will just change everything in sight and charge you the earth unfortunately.
i think unless i can get to the bottom of it, i will probably return to the uk and get it sorted. i really have no other choice i think. even though its gonna cost a few bob to get back to portsmouth
Post #174570 25th Feb 2013 9:52pm
Bob, this is going technical so i'll move it there...thanks for the warning . Thumbs Up ... - .- -.
Post #174571 25th Feb 2013 10:02pm
BOBCUSSEN
ok stan sorry about that Thumbs Up
Post #174572 25th Feb 2013 10:04pm
There's only 3 items on the lighting circuits common to all the headlights.
The lighting on-off switch, the steering column switch and the Lighting control module.
Even the various earths are separate.
Given that neither of the switches is likely to be capable of causing a 17s repeat failure cycle it leaves the LCM.
Thats what I would go for, can't think of anything else.
Post #174573 25th Feb 2013 10:08pm
BOBCUSSEN
well if it is that, then im happy with that even if it is around £300. Exclamation its whether i just take the chance and change it or pay probably the same amount again for the guys here to tell me just that, and end up paying double bubble Question Question
dont suppose it could be a fuse Embarassed Embarassed Embarassed Big Cry Big Cry Big Cry Rolling with laughter Big Cry
Post #174574 25th Feb 2013 10:14pm
Have you found the LCM yet? I would start with checking every connection to it, take them off then on again. Previously..
Post #174578 25th Feb 2013 10:20pm
You could have a look at fuses 9,4 and 53 which are 5A, 5A and 30A respectively or even change them for piece of mind but I don't think you will find anything.
You have my sympathy at £300 for a replacement lcm without being absolutely certain.
Is there no way you could find someone with a unit and do a swop?
Otherwise I'm sure they must be available second-hand.
Post #174579 25th Feb 2013 10:23pm
How about this then - http://www.ebay.co.uk/itm/Range-Rover-L322...2a29486121
Or here - http://www.ebay.co.uk/itm/Range-Rover-L322...35c38b1a67 Got - 2017 SDV8 Autobiography in Loire Blue
Post #174581 25th Feb 2013 10:25pm
BOBCUSSEN
hi contraband, yes i have been given the whereabouts of the LCM, if is behind the A pillar by the drivers door. i havent looked at it yet as it was snowing like a bas Censored ard on sunday.
i will check the fuses as suggested, and no i dont know anyone who has a RR to try their one Sad .
really it is either find a garage that can do a diagnostic on it without charging SEVERAL hundred euro, to tell me if it is the LCM or something else, or just change it and hope Question
i will firstly i think take all the connections off and clean them as you mention, then take it from there.
kind regards
bob
Post #174582 25th Feb 2013 10:36pm
you might consider buying a IIDTool which should give you an error code to work with...the only problem will be the time it takes for it to be delivered to you... ... - .- -.
Post #174583 25th Feb 2013 10:40pm
BOBCUSSEN
firstly alanm3, thanks for that, makes things a bit cheaper Thumbs Up , thinking about this a bit more, would i need to have a garage program this before it would work or could i just unplug the old one and fit the new one Question Question
the reason i ask is that my local dealer will not do this for me if i dont buy the unit from them Censored Censored Censored Censored
stan, i was considering buying one of these for future use, how much are they Question ; i have another vehicle to use so would not be a problem if i needed to wait for delivery. besides i am off to krabi in thailand for a month in 2 weeks so i could get by until my return i suppose
bob
Post #174585 25th Feb 2013 10:47pm
I'm not sure about this but I think a replacement LCM, new or used, has to be programmed to the car using Testbook.
Something to do with the cars mileage being stored in the LCM as a back-up.
Post #174586 25th Feb 2013 10:53pm
BOBCUSSEN
ok, thanks for that; nothing is easy is it Exclamation , ok guys i will have a check around the unit and its connections, check the fuses etc etc, and if nothing changes, see if i can find a garage that WILL put the testbook on it.
bob
Post #174587 25th Feb 2013 10:58pm
BOBCUSSEN
hi everybody. sorry i did not continue with this post but i have had a some rather huge problems to deal with personally over the last few months and thankfully it is all now sorted out so i have not been on the net for several months.
my headlight problem solved itself without really knowing what caused the problem. i just got in the car one day and switched the lights on and everything worked as it should. this was actually a few months ago but has been without fault ever since. sorry i did not inform at the time but it was simply impossible.
so i can only think it was possibly a water/damp issue of some sort that caused it as it was that time of year and there was a lot of damp in the spare wheel area?
anyway thank you all for your help.
bob
Post #201241 28th Jul 2013 12:12pm
