![]() | Home > Maintenance & Mods (L322) > Water / Condensation in rear lights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35852 ![]() ![]() |
that'll work ... |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
Solved the Problem !!! |
twhincup Member Since: 22 Feb 2012 Location: byfleet Posts: 109 ![]() ![]() |
+1, after reading on here, I drilled a couple of discreetish holes, watched niagra falls for five minutes and not had any issues since. Use a small drill bit and you wont even see the hole, although working brilliantly to fix the problem, obviously a 13mm drill bit might not be discreet enough ![]() 2003 4.4 LPG, Vogue, Silver |
sorry i didn't get back sooner, I've been at work, but dashed out earlier to get a photo for you:
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
thanks for the pics...
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3985 ![]() ![]() ![]() |
When I did mine I drilled two 3mm dia holes thro the bottom of the units, one in each corner, centred on the joint.
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 ![]() ![]() ![]() |
I also drilled from the underside, in the joint. I used a 0.2 mm (Dremel tool) and drilled three holes. They are totally invisible ----------
cheers for the help 2011 4.4 TdV8 Nara Bronze |
