Home > Maintenance & Mods (L322) > AC failure in one year time after replacement WHY ??
ebajema
One year after replacing the entire AC if failed again. Does anyone know of a good outfit that can provide me with some "what to do" to prevent this next time. I have to have the work done here and against better judgement I ordered the parts here as well (not this time, now they will be coming from the dealer in Holland).
I just want to prevent another epic failure.
For clarity, the compressor does start, and there more than enough gas in the system. MY 2010 5.0 SC Galway green and sand interior!!
Post #175096 1st Mar 2013 8:39am
how has it failed ? and how do you know there's gas in the system....mine went due to stone damage on the condenser and it seemed like there was gas but in reality there wasnt enough. ... - .- -.
Post #175111 1st Mar 2013 9:33am
ebajema
We tried to fill it up and the pressure of the system was perfect and the compressor engaged as well. That is why I need to talk to an experienced AC person to see what else I can test before I do another full replacement. MY 2010 5.0 SC Galway green and sand interior!!
Post #175112 1st Mar 2013 9:35am
i'd take the old gas out and fill from scratch ... ... - .- -.
Post #175116 1st Mar 2013 9:40am
ebajema
Why do you think that would help ? MY 2010 5.0 SC Galway green and sand interior!!
Post #175118 1st Mar 2013 9:43am
if air has got into the system through a leak then it needs to have the system 'purged' and refilled with gas..
you can check for leaks by using an ultra violet lamp.. ... - .- -.
Post #175123 1st Mar 2013 9:58am
You should never 'top up' the gas. It should be vacuumed out and then re-charged
Post #175125 1st Mar 2013 10:00am
Sounds like a control problem with possibly a component failure rather then the "whole" system failing.
Post #175126 1st Mar 2013 10:01am
ebajema
I am currently printing the workshop manual of the 2002-2005 system, hoping it is similar/same to the MY2006 system. Tonight I will hook up the Faultmate and see if I can find any issues/faults in the ECU.
Indeed better than just blasting ahead with a new system.
Also I will let them vent the system and recharge it to see if that helps. MY 2010 5.0 SC Galway green and sand interior!!
Post #175131 1st Mar 2013 10:04am
ebajema
The other thing I noticed is that the air from the vents is "warm-ish" not as cool as the morning air coming in through the window. Which doesn't make a lot of sense to me either. I didn't notice any condensation underneath the car but that is because I only ran it for a few minutes while we were "testing". MY 2010 5.0 SC Galway green and sand interior!!
Post #175132 1st Mar 2013 10:10am
Wonder if the FSR is playing up?
Post #175136 1st Mar 2013 10:22am
ebajema
The fan is blasting away happily, fan speed and control are fine. MY 2010 5.0 SC Galway green and sand interior!!
Post #175138 1st Mar 2013 10:23am
if you have warm air coming from the vents it does suggest that there is low or no gas in the system, is there any visible damage on the condenser.. ... - .- -.
Post #175141 1st Mar 2013 10:30am
ebajema
We didn't look for that yet Stan. When I go for lunch I will go and get try your replacement trick. If that works we know that we are chasing a leak. Not sure if you can buy the special leakage fluid here (they used on a car I had in Holland years ago) but will try. MY 2010 5.0 SC Galway green and sand interior!!
Post #175143 1st Mar 2013 10:32am
ebajema
Stan, I owe you a few drinks if we ever get a chance to meet !! Vented the system, refilled it and it is doing fine now. So we have a tiny leak (takes a year for the system to loose its coolant).
Now I am of course wondering if the previous replacement was necessary at all fuuk dammit. MY 2010 5.0 SC Galway green and sand interior!!
Post #175221 1st Mar 2013 5:33pm
