![]() | Home > Technical (L322) > Ignition fault |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
so you just insert the key [without turning it ?] and then press the red button ...
Nicka2311 Member Since: 29 Dec 2012 Location: Scotland Posts: 51 ![]() ![]() ![]() |
Start procedure is as normal, turn key to position 2 and press the button, rather than turning to position 3, which is now not needed, so it is the same number of steps and engine off is simply key off. I could bypass the whole ignition system and replace the barrel with the button start, but it would make it considerably easier to steal.
its very similar to the bmw start button jobby except for the extra key turn.....nice job btw. |
I'm missing the extra key turn you mention.
the bmw system is , put key fob in and fully press the start button ,with your foot on the brake for autos...
Ah ok, I know the mode your talking about, there is a 3 step way to work them as we use it to plug in an OBDII reader when reading fault codes.
