Home > Maintenance & Mods (L322) > LR Approved Used Scheme - Brakes
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
Hi,
Does anyone have experience with the inside mechanisms of the LR Approved Used Scheme and their internal checks. Just found out my brake discs and pads are almost 55% worn all round and need changing in the next 3-5 months but LR stealer insist these are within their tolerance levels and would not be changed under the Approved Used Scheme.
Thanks. MY11 Vogue 4.4 TDV8 - "African Queen"
Post #175355 2nd Mar 2013 10:58am
Your pads may well be 55% worn and perfectly servicable but I find it hard to believe your discs are 55% warn and have been deemed servicable by a Main Dealer. I wouldn't even consider driving a car with discs that warn.
I think you need to clarify the condition of your discs as a matter of urgency. Thumbs Up
Post #175371 2nd Mar 2013 12:19pm
They're not 55% worn, they have 45% life left in them Whistle
Post #175422 2nd Mar 2013 6:11pm
GreenBlood
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
My vehicle is also under Approved Used Scheme and recently suffered a seized caliper on the near-side rear wheel. This subsequently caused the disk to warp. Land Rover covered the cost of replacing the caliper but not the disks or pads. It seems to me that the used warranty does not cover those items that are subject to wear and tear.
They also covered replacement of the lower swingarms due to failure of the balljoints. The dealer had not expected them to cover this.
Cheers,
Craig If you don't get stuck then you are not trying hard enough.
2012 FFRR TDV8 Westminister
Gone: Def90 2.8i, Def110 2.8i
Gone: RRC 2-Door and 4-Door, 2007 FFRR TDV8 Vogue
Gone: Aussie Spec D1 V8, D2 V8
Post #175427 2nd Mar 2013 6:58pm
