Home > Maintenance & Mods (L322) > Rear suspension bushes
roger 47
United Kingdom 2012 Range Rover Vogue TDV8 Ipanema Sand
Hi to all.
I know this subject has been covered many times with regards to the replacement of the bushes and I have used the search.
However, I cannot find the method used for checking the bushes with regards to, up and down play and side wear.
I have, to my knowledge no issue with them but I am checking the car over, now that we have some better weather ready for the summer and the pending MOT in early May.
Any advice would be greatly appreciated.
I hope it's not a matter of waiting until they start to squeak or knock when you drive over bumps. '88 RR Classic, '90 Classic, '93 Classic, '02 Discovery TD5, '55 Discovery 3, '01 P38 4.6, '06 L322 Vogue TD6, 2012 L322 Vogue TDV8
Wife. '01 Freelander, '07 Freelander 2.
Post #176204 6th Mar 2013 6:27pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
its not so much up and down movement but back and forth where you get the movement, put a pry bar between the bush and the arm and lever it will show any worn bushes. Thumbs Up
Post #176212 6th Mar 2013 7:14pm
roger 47
Thanks arron for the info.
Will have a go tomorrow. '88 RR Classic, '90 Classic, '93 Classic, '02 Discovery TD5, '55 Discovery 3, '01 P38 4.6, '06 L322 Vogue TD6, 2012 L322 Vogue TDV8
Post #176247 6th Mar 2013 10:38pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
If you have a helper get them to push the car back and forth whilst you're underneath, handbrake on and in park, you'll soon see any play in the bushes.
Post #176248 6th Mar 2013 10:43pm
Have a look at this ...Click
Post #176265 6th Mar 2013 11:51pm
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
Listen ,the noise gives them away, Squeek when they are gone you will no it.
Cheers Piers.
Post #176285 7th Mar 2013 2:02am
roger 47
Thanks for the link 47p2.
Next question is that normal? The RR looks almost new, no road dirt visable. So is the side play there from new.
Therefore is piersie right in saying wait for the squeak.
Slightly confused owner. '88 RR Classic, '90 Classic, '93 Classic, '02 Discovery TD5, '55 Discovery 3, '01 P38 4.6, '06 L322 Vogue TD6, 2012 L322 Vogue TDV8
Post #176337 7th Mar 2013 12:49pm
The car lives in Colorado so mostly dry, won't go rusty like in UK, hence why suspension in such good nick (visually!). .
Post #176339 7th Mar 2013 1:00pm
TugRR
The guy's American - so I'm guessing an older vehicle living in a dry State ?
Thumbs Up Where do you go after one of these . . . ?
Post #176340 7th Mar 2013 1:01pm
arron
[quote="roger 47"]Thanks for the link 47p2.
no that's not normal, there should be no play in the bushes.
Post #176462 7th Mar 2013 10:19pm
