![]() | Home > Technical (L322) > Key battery low? |
piersie Member Since: 18 Dec 2010 Location: Berks Posts: 97 ![]() ![]() ![]() |
Sounds like its lost its sync. Get in car close the door,put key in ignitionand turn on dash(dont start it) turn off and hold key up by mirror,with your finger on the lock button start counting ,when you get to ten,press unlock three times,you will then hear your central locking click and its job done. (i hope)
Durham4416 Member Since: 10 Dec 2012 Location: Middlesbrough Posts: 248 ![]() ![]() ![]() |
Just have that a try and it won't work, unlocks the car and the boot but won't lock it |
Just had a mess on with both keys and now the key that was playing up is working and the red led light is brighter, still says key battery low though :s |
Now the wife's key is working and mine won't lock or unlock the car so I assume its not the keys, I mentioned it to my Indy and he said its usually the receiver in the car and it can be a pig to diagnose, hardly suprising, it's a range rover, anyone had similar problems? Also the car didn't lock itself as I set off as it usually does, I assume its related, it's like the car can only accept one key to lock/unlock at a time :s |
Have a look at BL's post about being locked out and make sure 100% that your mechanical door lock works!!
Both keys work manually in the door, foray it was my wife's key that was not locking the car remotely and now hers is working fine mine won't unlock or lock the car remotely, I'm going to try re syncing them when my wife gets home and see if that works, I wonder if being in the garage with all the other landrovers has messed something up because I can't think of anything else lol |
Just been out to the car and re synchronised both keys and now they both work, I'll report back if I have any furthur problems, it didn't work using piersies routine above as that's the wrong way round but thanks for the help, to do it you have to
4. Pat head and rub stomach at the same time while singing oh come all yee faithfull and felating a Bowhead whale.
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
What's the normal range of a key fob mine only unlocks about 6 ft away. |
Mine is a lot better then that, i would say 40' But not as good as my others, My Beemer 2010 320d is half a mile .
Well after re programming they worked fine for a few days but now the wife's won't lock/unlock again, hmmmm |
Are the fobs cold, or warm? If they are cold this could generate the key battery low message and cause the problem? .
Geo2toy Member Since: 04 Nov 2012 Location: Wiltshire Posts: 76 ![]() ![]() ![]() |
Replace the battery in both fobs but remember to press the buttons on each fob when battery is out to remove residual charge at least thats what I was told to do and it worked. |
