![]() | Home > Off Topic > Crap i-phone update |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
I think I've got the same issue, but hadn't connected the dots to the SW update.
I've heard a few complaining about this |
You can turn those off yourself tho in settings … |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
I know Mick, I just wondered if maybe the upgrade had turned them on without you noticing. Sometimes code upgrades do that to test you out! |
If Apple don't sort it the phone will be turned against a brick wall …. |
One of the reasons I'm holding off is that the same thing happened when the 4 came out, and folk with "old" 3's upgraded and they had no end of problems.
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
I have a iPhone 5, used to last more than a day, now back to charging every day
Just about to activate my ip5 just now ….. |
i have mine plugged in as much as possible now. it was about 92% at 4.40 and is now 51% with just a few emails checked and a 10min call and some text.
I always shut the apps down |
Next thing is turn off location services and vibrate and screen brightness. Mine is quite low as its much better in any light conditions but still have it set to auto adjust but it keeps it dimmer than the average one. Good for privacy as well |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Mines ok.
But it's this latest update that is causing the battery problem before it the battery was fine |
