![]() | Home > Technical (L322) > Possible Injector Failure |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Will, have you tried the underbody pump? We change these quite alot and all won't start but will with easystart then run quite happily... Usually down to diesels being wrongly filled with petrol though... |
Changed recently and i can hear it priming and the fuel going thru the filter into the clear line with no bubbles so thats flowing ok as well as the intank one |
No petrol in it at the minute as far as i know. just 75litres of sainsburys stuff...
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 ![]() ![]() ![]() |
Could be drawing air from somewhere on the intake side, ie any pipework between the air filter and engine and also the inlet manifold gasket. if you suspect anywhere you could try spraying some easystart at the area and see if the engine revs change. it might work. also try disconnecting the maf sensor to see if that makes any difference and try cleaning the sensor too. does it run ok when reving higher under boost? '04 td6 se
As an update this is what my MSV2 is telling me |
