![]() | Home > Technical (L322) > torque converter |
| The doc Member Since: 25 Mar 2007 Location: In car hell :-( Posts: 425
Get yourself a warranty from these guys - I have two with them and there great - includes wear and tear.
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
hi thanks, would that be two torque converters or warrantys...
| andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160
hi daveo
hi my one cane to about 1200 pounds, where abouts are you.. V8 facelift Range Rover Autobiography 22" wheels.
down in surrey woking
ok, i am in walthamstow, i used a garage that has got technition from stratstones in woodford, they done a wonderfull job, collected and delivered, how bad is the shuddering... V8 facelift Range Rover Autobiography 22" wheels.
it does shudder after it has warmed up and and only on light throttle, but not all the time did yours make a noise or just the shudder
hi , no noise just lightly shuddered under light throttle, around 25 to 30 mph, after it was done the changers were smother and didn't change up and down so much. sorry to tell you but i don't think the warranty will cover it as they did the same to me, they let the garage strip it all down and then wanted the torque converter cut opened and because there was not broken parts they put it down to wear and tear.. hope this is not the case with yours...they then went on to say that oil and filter ect was not covered so i told them to poke it right up there hole...and paid for it my self..DON'T USE A SECOND HAND CONVERTER.. you could be back to were you started in 6 months...
good tips thanks
| jdog30014467 Member Since: 29 Jan 2014 Location: north london Posts: 6
hi there im new to this site and not to sure how it works so hopefully am posting in the right place. Here goes ibought my rr 4.4 v8 recently and it vibrates when I get to 25 mph 1500 rpm [ cattlegrid effect ] it only happens at low throtle in third gear but disappears after 40 mph and doesn't happen in manual/sport ive read a lot of these threads and this sounds like torque converter failure ! all my gear changes are fine so im hoping ive caught this problem early. my car has down 125000 miles and I don't think the box has ever been touched before , could anyone tell me the process of how to pinpoint the exact problem pls or any other relevant info would be much appreciated thanks. 2003 range rover se autobiography 4.4 v8 |
| All times are GMT |
