Home > Maintenance & Mods (L322) > Checked the side play on the top rear bushes
roger 47
United Kingdom 2017 Range Rover Autobiography SDV8 Fuji White
Hi
Following on from my previous post I have checked the top bushes and found a slight side play.
so I measured it and it is 0.11 inch with 49000mls.
Question, would that be an MOT failure or is that normal wear within tolorance.
Thanks. '88 RR Classic, '90 Classic, '93 Classic, '02 Discovery TD5, '55 Discovery 3, '01 P38 4.6, '06 L322 Vogue TD6, 2012 L322 Vogue TDV8, 2017 L405 Autobiography
Wife. '01 Freelander, '07 Freelander 2.
Post #176768 9th Mar 2013 2:56pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
that depends on the mot tester, how stringent is he going to be. my self personally i don't like any play as its not suppose to be there but from a testers point of view its probably within limits.
Post #176809 9th Mar 2013 11:44pm
When you say play... What do you mean exactly? You can put a prybar in and thats how far you can move it? When you move it with a bar it should spring back to its original position...
Post #176834 10th Mar 2013 11:35am
roger 47
Thanks C-T-C .
The play is the side movement of the joint along the direction of the securing bolt towards the rear of the car. When you release the prybar the joint springs back to it's original position.
As I stated the side movement was 0.11 in on both sides.
As the movement is even on both sides, either, both joints are wearing together, or, it is normal movement of the joint.
Is the joint preloaded, similar to some ball joints? in which case there will be a slight movement. '88 RR Classic, '90 Classic, '93 Classic, '02 Discovery TD5, '55 Discovery 3, '01 P38 4.6, '06 L322 Vogue TD6, 2012 L322 Vogue TDV8, 2017 L405 Autobiography
Post #176848 10th Mar 2013 12:33pm
