Home > Maintenance & Mods (L322) > What's your opinion on these?
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
http://www.ebay.co.uk/itm/RANGE-ROVER-2013...565210d441
Thinking of ordering one of these as a bit of an upgrade to mine which are not mounted quite correctly, what do you guys think? Also what is the difference between SDV8 and TDV8 ? Excuse the ignorance. Mr. Green Mr. Green Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #176855 10th Mar 2013 12:59pm
verydisco
Hi,
This logo is not meant to be fitted to your 4.4l tdv8
This is for a 2013 sdv8 L405 Rangie
Even though the engine is almost the same unit in both vehicle, it is now branded as a SDV8.
If your logo is wrongly fitted, you may delete I'd altogether as I did or refit a 2011 model one.
This is quite easy to do and you may simply measure correct fitment on another member's L322 tdv8 Vogue.
Ps: why is it wrongly fitted to start with? Has it been repainted ?
Cheers. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #176869 10th Mar 2013 2:09pm
Pfazz
Thanks for that, it is wrongly fitted because it came out of the factory badged as a vogue and not an se so when I raised this with the dealer he said badging isn't covered under warranty and I had to pay for the se letters which he then just stuck on the end of the vogue ones , this means they are now slightly out of centre to where they should be. I may try and remove and reset them with twinstick tape when the weather gets warmer. Agueroooooooooo. 93-20
Post #176874 10th Mar 2013 3:24pm
If the dealer did not fit them correctly can you not take it back and get them to do it properly? Previously..
Post #176875 10th Mar 2013 3:35pm
Pfazz
Well really I should take it back but time has passed since it was done and in my foolishness I accepted it as it was thinking it would be ok but it seems to catch my eye because I know it's not quite as it should be. My bad I suppose. Agueroooooooooo. 93-20
Post #176880 10th Mar 2013 4:17pm
